Problemas with "affiliations"
Maximiliano Altieri shared this problem 19 months ago
Known
Hi. I'm having a problem loading data.
First I charge an organization. Then I post a profile or a festival, for example.
When I want to upload membership to an association that is already loaded, the association does not appear to me. What can be the difficulty?
For example, my profile (Maximiliano Altieri), in the "AFFILIATIONS", I belong to the Association Teatrantes Bariloche, which is already loaded, and does not appear.
If the association is already loaded, with the first few letters the option should appear automatically.
What could be the problem?
I'm also putting this in the forum, but I'll give it to you to keep you informed.
