Profiles website links do not work
Paola Pilnik shared this problem 20 months ago
Solved
When I click on some of the websites on a certain individual or company's profile it doesn't work.
Comments (2)
95
Hi Paola,
This is happening probably because the link isn't fully written out such as "http://worldtheatremap.org";. Maybe try adding the http:// or some other configuration of the URL or domain name to see what it requires in order to become a clickable link.
Thanks,
Vijay
74
Hi,
A similar problem happens to me:
When clicking on a link in the 'contact info' box of any profile, the system takes you to the wrong URL.
It basically deletes the : (colon symbol) that goes after the 'http/https' from the URL, giving as a result a page not found error.
You can see an example in this profile, which I created: https://www.worldtheatremap.org/en/profiles/zznHPiCK7eaHMsYnd
The URL is correctly written; I even tried to copy-paste the link through the notepad to make sure it is not carrying any format or mistake. You can also hover over the link and you´ll see the incorrect link at the bottom bar of your web browser.
By the way, I am using Chrome
Any ideas?
Thanks
